Old directv 18 inch dish | SatelliteGuys.US
johnny58259
190
I have an old directv 18 inch dish with a regular dual lnb. Was wondering for rv ing perposes could I use my h24 or one of my h23 receivers just to get my standard channels when I go camping of if not would a d11 or d12 standard receiver work with an old leagacy 18 inch dish.
Any of those receivers will work with an 18" dish. Like you said, sd channels only!
Yes all those receivers mentioned work with the 18 inch dish. Just make sure you select 18 inch dish on the settings and also choose "multiswitch"
So choose multiswitch even on a regular dual LNB. Also I guess the only swim only receivers is just hr34 and h 25 so the h24 will work with swim or leagacy old round 18 inch dish.
trrench or run line overhead DIY
Setting up SL3 Dish (Code 771)
