Just wondering ....
I have an old D* dish. Can I change out the LNB, and maybe use it to pickup a E* bird like 61.5?
Depending on your switches and receivers that old D* dish is actually compatible with its existing LNBF, it would however be considered a "legacy" LNBF.Just wondering ....
It depends on what type of LNBF and/or Switch you may be using, so....
What type of LNBF is on that Dish 500? 1 DP Twin, 2 DP Duals, 1 DP Quad, 1 Legacy Quad, or maybe 1 DPP Twin.
What type of Switch are you using, if any?
Limited time offer
