old and new | SatelliteGuys.US
old and new
usnret997
6
Milton FL
I've upgraded my recivers. Now I've added a fifth reciever. The older reciver is taking the signal from the newer box. I'm using a in-line signal amp on the new reciver. still no help. Any help with this would be highly helpful.
I think we need to know the receiver model numbers!!! And what dish etc you have?
I ask because I don't know what you mean by "older receiver is taking the signal from the newer box".
I guess I should have given that information. The new direct tv reciever is D11, the old one is a Hughes SD HBH. The in-line amp is a satalite ampifiler 50-2050 Mhz. The in-line is going to the new reciever, tried it before the splitter, after the splitter, then on each line, same thing happens.
are you using a splitter like a cable splitter or a multiswitch, if you are using a cable splitter it will not work
you will need a multiswitch for 5 receivers
Back to basics. The four lines from the dish connect to the WB68 mulitswitch and then you connect to the receivers. No amplifiers should be needed.
Are there ANY former E* users that have switched to D*?
Using remote from another room.
