Sean Mota said:HDCP = High Definition Copy Protection. It is a flag that your HDTV must have in order for the signal to go through the DVI/HDMI port. If your HDTV is not HDCP compliant, you must use the component input of your HDTV. Get your manual or look up the specs of your HDTV online to see whether it is compatible or not.
2005FPWSean Mota said:No it is serious... This is Hollywood nonsense. There is no way to get around it. What is the model of the Dell monitor.
High Definition Video – We played the WMV9 1080p and 720p versions of "Under Sea Adventure" to give our monitor a little taste of high definition video. In many of our previous analyses, we simply ran WMV9 content unscaled to test color depth and clarity. However, since both the Apple Cinema and Dell 2005FPW are capable of widescreen unscaled aspect ratios (at least for 720p), we thought it best to put both of these monitors completely through their paces. No surprise, but there doesn't seem to be any corruption or shifts in any of the colors. However, keep in mind that neither of these displays supports HDCP! We could not watch 1080i or 720p signals on either display from a regular Comcast HD receiver, since neither display has a DVI-HDCP input. While pin compatible, any HDCP source simply terminates after a few seconds of video. The Dell 2005FPW has a few additional inputs, so we can actually use a component-to-VGA (15-pin D-sub) cable and watch HD content in this manner. Of course, for the same reason why we don't encourage anyone to use 15-pin D-sub cables for regular computer use, we really don't recommend D-sub for TV either if it can be avoided. Unfortunately, in this scenario, it cannot.
J3ff said:"use a component-to-VGA (15-pin D-sub) cable and watch HD content in this manner."
if i did this, would i still get a REAL HDTV resolution?
Sean Mota said:Yes... Remember that PC monitor has capabilities of high resolution and the component input is not required to have HDCP.
J3ff said:yeah but doesnt a vga cable not show as good or sharp of a picture as a DVI cable would?
Limited time offer
