NSS 806 in canada | SatelliteGuys.US
NSS 806 in canada
brotherhood
397
97w/55n
hi guys
what is the srongest tp on NSS 806?
trying to get this sat for a co worker which he has a 4foot offset
thanks
I guess you will need a bigger dish 66" minimum , C-band LNB with the Dielectrac installed inside the LNB and a blue conical ring. The Venezuelan mux is a strong one
3880 R 22117, City TV 4130 R 3844, Colombeia TV 3632 R 2712 and ERT World 3630 L 3333
Good Luck!!
Some transponders on NSS 806 can be received with a 4 foot offset, at least in southern Ontario. However, I'm not sure if the signal will be strong enough at your location (i.e. 97W 55N).
NSS 806 is not strong like it used to be, i was using a 6 footer for 806 and use to get 80% off the channels .I re- point the 6 footer to AMC 1 @103 and moved one off my 7.5 Unimash to 806 so i can receive those channels .
rfd
Receiver Question
