not getting signal in sat intelsat 14@45 | SatelliteGuys.US
manuelpaz
198
usa
Hi guys
if someone can explaint me this. is really hard now to get signal before i was getting good signal in intelsat 1R @ 45 but now the they changed name of satellite for intelsat 14 not signal i was getting good signal in tp 4071V 2615 or 3759V 4412 if anyone can get me some answer i'll be happy.
Thank u guys ur friend Manny
I just check those Tps an both are their an 1 TP is real hot. now I have them both a 1-mhz higher than what you posted, 3760-V is 83Q & the 4072-V is 98Q both with the AZ receiver.
so to answer you're ? would have to say look at you're dish alignment, or you're pole that the dish is mounted on that nothing has moved. I have noticed that my signal has increased on the S2 muxs their ( we watch them the most on this sat) when they did their changes over to IS-14. so good luck hope you find where you lost you're signal at, could be just a bumb or 2 of the dish.
hello 1 captain
Really thank u for the info i was worry but now i'm happy for ur comments. i'll try to get it later.
thank u , Manny
SPS Satellite Programming Service Inc.
my 4dtv dsr922 at evenings unable to get signal
