Non adjustable feehorn F/D? | SatelliteGuys.US
coinmaster32
916
14
USA
I have a chaparral feed that does not have an adjustable F/D. Does anyone know the F/D of it so I can set it on a new one?
I have one of those, I compared the distance the throat sticks out to the adjustable feed I was replacing and they were the same, about 3/4 inch. I bolted it in place, worked fine. If you have a button hook feed you can slide the whole assembly in and out for optimization. With support arms you might play with spacers or washers to improve it.
openbox s9....prooooooblem
Unable to add TP on a Viewsat Ultra
