No Way to contact anyone if you decide to cancel my registration | SatelliteGuys.US
shanklej
228
17
Ocala fl
I had to register again to gain access. Could not use my old username or password. Wasn't able to reach anyone in administration without registering again. I also can't find the Reels channel on 91. Fat Air told me to try 3887 H 19759 but the signal is weak and Reels did not appear. Someone in administration should try to write a message to see the errors and difficulty of using it. That's why this message is all jammed together.
I can't find the Reels channel on 91. Fat Air told me to try 3887 H 19759 but the signal is weak and Reels did not appear.
I have that one on 3890 H 19748 with my Openbox S9 on a 7.5ft dish, and, it will rescan in if I delete that TP and rescan that satellite.
Thanks guys for responding. Everything else seems to be OK Fat Air, so with my lack of experience I am hesitant about doing any adjustments. I will give 3890 H 19798 a shot tonight. I assume it's on 91. Thanks Lone Gunman
When doing adjustments ALWAYS keep notes as to how much you change, ie, move declination? Log how much, which direction and what the result was so you can get back to where you were and NEVER change but one thing at a time so you can keep up with what does what. It's not rocket science, just have to pay attention to details.
And yes, that's on 91w.
First thing to check is "is the pole plumb" then go to you most southern satellite and check the elevation. Then off to one side and check the azimuth.
Thanks Lone Gunman and FaT Air, Got Reels last night fine. Good strong signal. The pole is sitting in a 3x3x3 block of concrete. It will take an earthquake to move it. Overkill I know... It is plumb. Seems Nikita is seeing it's last days and the same with Arrow. Sorry to see Arrow go but Nikita is starting to lack. Still having trouble with the way this message is formed. Hope SatGuys gets it straightened out. You guys don't seem to be having my problem?
BUD Install Location
87w 4154 H
