No Video for some channels on IA5 | SatelliteGuys.US
TFSAT
12
Hi,
Does anyone know why some channels on IA5 like M2 Maroc and Kuwait TV have no video?
I receive their transmission fine (good signal quality and strength), the audio is very good quality, but no video and my receiver displays a NO VIDEO SIGNAL message.
Thanks.
TF
Rebooting the receiver (Digiwave 7000) did not make any difference! This problem has been there since I setup my sat. equipment 5 months ago. I thought it was normal for these 2 channels.
Has anyone experienced a similar problem with these or other channels?
I seem to remember seeing a note somewhere to check the "PID". What is the PID and how can this cause my problem?
Thanks for your help.
TF
One of the things, I had to do on a couple of channels a few weeks ago was delete them then rescan. This seemed to clear up the problem I was having with Audio. Have you tried this?
Rick
Thank you, Rick. But, deleting the channels and re-sacnning did not fix the problem.
I think it has to do with the Video PID. But I am not sure what it is and how I can set it on my receiver.
TF
M2 Morocco info:
11991Mhz
22Msps
Vertical
SID: 02C1
PMT: 003C
PCR: 0110
Video: 0110
Kuwait TV info:
11991Mhz
22Msps
Vertical
SID: 02BE
PMT: 0022
PCR: 0140
Video: 0140
Don't know if this will help, but I thought it'd be worth posting for you ;)
Good luck!
Does size REALLY matter ???
Primestar lnb
