no signal | SatelliteGuys.US
no signal
hrtland2
13
Hi guys.i need some help.yesterday,i put up a 500 with a dp dual,in order to get 61.5. it's routed directly to the extra port on my 1000.2(triple lnb 110,119&129) I have never picked up a signal for 61.5. my starting point was 140 azimuth,38 elevation & 90 skew.adjustments have not helped.check switch shows good connection,no signal.i have verified that the lnb is good,my mast is plumb & i have no los issues.southern il ,62923.i have no problems with 129,but i need the 61.5 for csn ne hd.thanks in advance.
Adding Dish 500 to Dish 1000.4
722 and OTA problem
