no signal on 110 | SatelliteGuys.US
no signal on 110
It Sounds Like The Elevation Is Sagging A Little. This Will Drop 110 Below The Check Switch Threshold And Allow 119 To Appear Ok. Also Wether Your Using A Dpp Twin, Or A Dp34 To Bring In 61.5 , This Obviously Will Not Affect Your Wing Dish Either.
I would like to advise you do search and read the forums - your particular problem and troubleshooting technics discussed so many times - practically nothing to add.
Need Help finding 61.5!
VIP 411/211 & Dishpro equipment
