no signal in Portland OR | SatelliteGuys.US
sherrill
Portland, OR
no reception tonight beginning around midnight. message on all channels is searching for a sat signal. Is this happening to anyone else?
Clear any obstructions away from the dish, then check all connections for corrosion or water intrusion. If you have an in-line power booster, reset it. 85% of the time you will clear the trouble by following the above.
Can I just say no to SWM
Dish Change
