No Signal I need help!!!!!! | SatelliteGuys.US
david3443
Hey guys I'm a newbie here and I have a problem, this morning I noticed my signal was not coming in on my HDDVR receiver in my living room so I went out site to slightly adjust the dish. Well now I have NO SIGNAL and the kind people at Direct TV said they cannot have someone come over until the 14th a whole 10 days from now. So I wanted to know is there anything I can do myself to fix the problem
Thanks in advance
David
Also, remember the tweaking is not instance, so move the dish slightly, give it a second or two for the strength to pop in.
also,, did you loosen the bolts ?
I usually suggest just placing a small amount of pressure on the dish sides and see which direction corrects your problem, then loosen slightly to adjust.
Only takes slight movements, chances are if you didn't loosen all the bolts you can still work with what you have.
Try left and right first, then up and down, with slight pressure on the reflector.
When you get signal back you will know what adjustments are needed.
Jimbo
DirectTV Locals subscription + OTA Antenna Possible?
Portable DirecTV HD Dish
