No RF setup | SatelliteGuys.US
No RF setup
jappleboy
312
Just got a HDVR 22 from best buy. Has a bigger hard drive to hold 100 hours of HD Movies looks great in black. Why did thay take out the RF setup.:confused:
If you're talking about an RF output probably because you don't get HD out of RF, only SD and they figured the vast majority don't need it. If you need RF out you can get a RF modulator and connect it to the composite or S-Video outputs, they are always active.
If you're talking about RF remotes, it's there, just that the antenna is internal to the box.
If it is the remote, press menu-parental/setup-system setup-remote-IR/RF setup:up
slimline wiring for video on demand
little help
