No "Resume" on HWS DVR Events | SatelliteGuys.US
There is a bug, resume does not show up in the popup menu unless you are in Folders-By-Title. It will work by pressing 'play' in all cases.
At least both Hoppers allow you to back up once you have reached the end of play on the EHD. The 722 did not.
You must do it before doing much more or you can only start over to see that last part easily.
-Ken
Do you have your folder view set to Genre or My Folders? Try changing the view type and see if it appears.
Yep, was set to genre, this is now the only setting that shows that I have watched part of a recording, and I need this, so I will keep that setting.
Dan
Changed TV's need 3rd Joey. Lease or Buy?
Other than the iPad, what is the best tablet for Dish Anywhere?
