GEOSATpro - No Picture on TV with HDMI??? READ ME FIRST | SatelliteGuys.US
GEOSATpro No Picture on TV with HDMI??? READ ME FIRST
Mr Tony
3,399
14,909
Mankato, MN
Figured I'd post it since its come up a few times
If you hook up the Micro to your TV via HDMI and you get no picture DO NOT WORRY!
There was a glitch on the original software which defaulted the display to 1080p which alot of TV's wont do. This results in a handshake issue (no signal)
The easiest thing to do is hook up the A/V cables (red,yellow, white) to your TV. This output is hard coded to 480i and your TV should be able to see that.
Go into the menus
menu
down to 3rd item
over to TV System and hit OK
scroll to 720p and that should work on your TV through the HDMI cable
Then load the newest software which is here
http://www.satelliteguys.us/microhd-discussion/287766-folks-who-got-their-microhd.html
That defaults to 720p on HDMI. You can change it to 1080i if you want.
GEOSATpro feature request: longer auto standby timer
GEOSATpro HD DVR Recording Playback Problem
