No odd transponder. | SatelliteGuys.US
No odd transponder.
martin1
79
No odd transponder. I check the signal strength and odd is 0. What could be the problems. I have two D10. I switched the coax from dish where it comes into house and the trouble stayed with the same D10. So I know it either the inhouse cable or the D10. Which voltage does the odd use 12v or 18 volt. Would this cause no odd transponder?. This was a Monday new install and was working just find till today. I also have a R10 which is working just find.
On my D10 the Odd is 13V (change to channel 490)
and the Even is 18V (channel 491).
It maybe the switch. Or loose connect somewhere.
Hope that helps.
Hope that helps.
I fixed my problem. You won't believe this but was bad connector that installer put in at entrance to inhouse cable. Thanks for help.
Samsung 360 and connections
Directv
