No Line of Sight for Install... anything I can do? | SatelliteGuys.US
czarqwerty
50
The installer came today and could not find a line of sight to all 5 satelites.
My zip is 17745 and I'm getting HD. He said that Directv requires I get a 5 LNB/Swm setup even though I don't need all of them after the receivers are activated.
He was able to get a line of sight for the 3 satelites i would use but wouldn't do the install because the receivers wouldn't activate.
Did he give me correct information and is there anything else I can do?
Thanks!
What did he say was blocking the signal?
Cut some trees down? No jokes, find out and cut them down, or trim them up.
Did you suggest a pole mount? 2" post concreted into the ground at the back/side/somewhere with a los on your property.
Trees are in the way, but they are not on my property. He looked for pole mounting options as well and couldn't find anything.
have you considered ordering your account without locals, that way if you need the swm5 lnb, you could get away without it. then use an offair tuner for locals.
just a workaround suggestion.
Thanks for all the comments... here's more information. I cannot receive OTA because none of them reach me. I currently have dish network which is on 110 and 119. I'm not sure which satelites he couldn't get.
Based on a zip search on TV Fool a good, well aimed roof mounted OTA antenna you should be able to get some locals.
Does the OP actually require the 110 and 119 sats?
his zip is in Wilkes-Barre DMA which SD locals require 119. According to D* all of his locals are in HD but My & CW so he does need 119 (unless he doesn't care about those 2 stations). The Big4 + PBS in HD are on 103
Directv needs 99/101/103 for the "main" SD & HD channels
119 is for some locals markets which for SD locals yours is one of them (post above)
If you look to the left from behind the dish what does the line of site look like?
Iceberg, thanks for the explanations. Right now, the E* dish is barely clearing the trees for 110, 119. In a few years, I might have problems.
The E* installer had to do a tri-pod pole mount on top of my roof. The dish is about 4' above my roof. The D* installer said he didn't want to do that because the D* dish was 42 pounds and was afraid of a strong wind blowing it over.
I don't really care about CW and My too much, but the installer wouldn't try anything because he said the HR-24 receiver wouldn't activate without signal from all 5 satelites.
He did say he could get the 3 main ones, which I assume he meant 99/101/103.
charper1, thanks for the idea.
Here's how tvfool shows for my exact address. So if I'm reading it right, it will be tough to get anything.
The HR24 works fine with the 3LNB (99/101/103). Lots of folks signing up have a HR24 and the 3 LNB. If he does it that way then the 2 SD locals wont even show in the guide
Yep maybe so, BUT if it were me I would still set one up anyway just to see, but thats the DXer in me; cant hurt to see what you get. Here is what I get based on your addy. Wonder why the difference? Maybe worth a try with something like a Winegard HD 9095P
You have a lot of channels you could get with a good OTA antenna, with a rotor.
70 miles is about the extent of most antenna's, however you can get farther if you work at it, but most of your stations are much closer.
Unless your talking about just an inside antenna or a small OTA antenna.
With digital signals the HIGHER the better.
I have a full size antenna (from Radio Shack I think) at the peak of the house and get great OTA reception, I put up a rotor so I can move it and get another market as well.
Interesting. He said that for my area, directv requires a 5 LNB or the receiver won't activate. He mentioned that if I lived in an area nearby, they only require 3 LNB for that area. He kept saying the receiver won't activate.
A supervisor is supposed to come out and double-check. Hopefully he'll agree with you.
I'm down in a small valley, so it'll be tough. But maybe I'll check Radio Shack's return policy and give it a try. I never did before because I figured I'd be wasting my time and money.
new here
AM21 OTA Module, Diplexers, and DECA and MRV ? ? ?
