No input #2 on sat. 129? | SatelliteGuys.US
alpenliter
southwest usa
Hi folks, newbie here. I'm in an RV, using a Kingdome 9702. Dish says I need to be on sat. 129 to get locals in HD. I have a good signal strength, did a check switch and a reboot, but the check switch says input #1 OK on sat. 129, but just XX on input #2 and Switch SWAJ. I can't record one program and watch another and some channels won't record at all. Like I said, newbie here. Oh and the receiver is the Vip722k. Thanks in advance for any help!
welcome :wave
You need two cables from the dish to the receiver. The kingdome units are what they call Legacy so you need two lines to the receiver.
You already did a check switch but I had this same issue before too. Select "Alternate" in the check switch screen and see if that fixes it. It shouldn't say any switch if you're aimed at just 129
Dish Customer Service is Ridiculous
Replace 222k with 211k
