no audio with HDD 200 | SatelliteGuys.US
dumbjim
20
st. louis mo.
Every once in a while when I swing over to G9 to watch HBO hd, tha audio is present until the video comes in then no sound. I then unplug, and replug the HDD 200 any every thing works fine. Does anyone else ever have this problem?
thanks,
thanks,
I have experienced the same problem on occassion. However, after the reset the HDD 201 would be ok for several months.
Is yours acting up every time you move over to HBO?
inner switch on lnb
How can I tell if my LNB is going bad?
