No audio on TVO- Shaw direct. | SatelliteGuys.US
tay243
18
No audio on TVO(353), anyone else have this problem.
Knowledge, Access and other channels all OK.
You don't say what receiver you have - so do the old Motorola trick - pull power cord for a couple of minutes to clear cache and force a hard reboot.
Thanks Jumbo for the reply.
Just a basic four banger DSR207. I fiddled about with the user settings for Audio and
that seems to have solved the problem, the audio is back for TVO.
The mystery (to me anyway) is whyTVO was the only channel affected.
Why Is Bell ExpressVu Deleting Channel 814 - HDNet?
ShawDirect HD install help needed - located in Harlingen, TX
