no audio on tv | SatelliteGuys.US
no audio on tv
rodder
2,351
105
Adairsville,Ga 30103
had voom installed on sat 1-8 run dvi to hdmi to tv with rca cables and run optical cable to stero reciver sound is fine from reciver but no sound from tv.
tv is sony kp57ws520
I had the same problem with my Samsung HDTV. It requires separate audio inputs when using the DVI input. The Voom box has stereo audio outputs. Try connecting a cable from these outputs to your TV. I hope this helps.
Program Guide Errors
Problems since installation
