No Audio on PBS AMC3 | SatelliteGuys.US
rjc3895
390
Several of my PBS channels on AMC3 have no audio. i have 52% quality signal. I have a Traxis DVB 2500. Other AMC3 channels have audio. Any suggestions?
The PBS stations have AC-3 audio output. Need a receiver that will support that
The traxis doesnt...neither does my Pansat 1500 :(
The Pansat 2500 and Fortec do
The Traxis 2500 does not have an AC3 output? If you want the AC3 audio you need to upgrade to a Fortec / Pansat or any receiver with an AC3 output, then you will have to plug it into a AC3 stereo/receiver, a lot of the new cheapo surround sound systems have AC3.
Thanks.
AC3 and blind scan are the must-have items on my next receiver. This is what happens when I decide to go el cheapo. :)
rjc
When I first got into FTA, I got a REAL El Cheapo one...$60 bucks
no scanning
no motorized
10 entries...each TP is a entry!
twinhan 1020
I just got the el cheapo twinhan 1020a (also called Vision Plus) DVB-S PCI computer card myself.
Waitng on a 90cm dish to arrive for testing.
just a note that this card has AC3 support for those PBS channels
not sure about the blind scanning feature dont think so.
No existing DVB card has hardware-based blind scan. I've read there were some software implementations of blind scan, but due to the extremely low speed they were practically unusable.
On the other hand, every DVB card is by definition HDTV and DVR (and HDTV-DVR) with AC3 and 4:2:2 support :)
Need some more help
Dish tools
