No 4:2:2 Channels | SatelliteGuys.US
No 4:2:2 Channels
Phoxx
72
The Land Of Corn!
I have "North Americanized" my P+ and now I can not scan in any 4:2:2 channels. Did I miss something? I deleted all the sats, then added all the sats between 60 - 139 degrees West. All of the regular channels work just fine, but, no 4:2:2 stuff???? Might there be a file I erased on factory reset that I must now add?:(
Only problem I see is that the GDMX stuff has no video , when I looked, except for one test pattern. Still , the channels should scan in, they do on mine ! :) The 107W stuff has active video, if the OP can get 107W Ku.
most of the GDMX channels now have color bars and the time at the bottom when not being used. At least the 1st 2 channels do
Thanks for your input guys. I was trying to get the 4:2:2 MUX on Galaxy-28. I was able to get a scan now, but the signal is on and off. Are these channels no longer available?
AZ box shortage
Has Azbox fixed Diseqc 1.2 issue?
