Nightly Downloads | SatelliteGuys.US
Nightly Downloads
jmccue
Newbie Q.
Service installed five days ago. No problems except every night about 2am my system downloads updates and new data. Fine, except after the download it leaves a user screen saying "Press select to continue" and just hangs there until I press select. Mostly I want to record old movies, many are broadcast in the early morning. Is there some way I can make this download return me to my program automatically?
Sorry if this is an issue you have all dwelt with and consider "moron level", I did search the entire forum and found no similar question.
Mac
i assume you are talking about a DirecTivo unit? if so you might have better luck in the DVR forum. if not, what reciever are you talking about?
That is the description of a DISH DVR screen you are in the wrong forum. I suggest doing a search on your DVR then set timers for the programs you want. The DVR will turn on and record the programs then return to the DISH screen saver.(hopefully)
New Access card
? about adding Sat-c 110 LNB
