Newby help | SatelliteGuys.US
Newby help
lgb0250
368
318
Coming over from D* this Friday. I have a 32" LCD HDTV and a 40" LCD HDTV and two SD TV's. I'm going to be getting the GoldHD package with the upgrade 622. I've also purchased another 622. My aim is too be able to record off of both the HDTV's and run the TV2 on each 622 to my SD TV's.
I live in the Raleigh market and have seen where the local HD's have been uploaded but are not active yet so I assume I will need an OTA antenna also.
NOW, since I've spilled my guts is there anything I should be watching for or asking for during my installation?? Being with D* and not having HDTV made life pretty simple. I've read a ton of posts trying to catch onto this but this new setup seems really quite complicated to me. Probably because I'm getting older and everything seems to be more complicated. Thanks for any and all help to a newby
If you want to run the TV-2 output on both 622's to both SDTV's you just use a splitter to combine the SD output from the 622's and set the TV2 output on each 622 to different channels.
Sound track problem on CBS' Cold Case
LNBF Fee?
