Newbie Question to get started | SatelliteGuys.US
bappida69
Hello,
I am a newbie to the world of FTA and have been looking at the forums/FAQs etc for almost 2 weeks now. I think I have understood the concept behind FTA but have very basic question about what I need to buy to set up FTA. Here's the information:
I purchased a house and my previous owner had SuperDish installed on the roof. I can see LNBs(2?)from down below. Owing to the height of the installed dish, I can't get up to see the dish in more detail. But from my neighbour I understood that the previous owner used to have good quality dish coverage for many years. I have subscribed to cable for some time. So the questions are:
(1) If I buy an FTA receiver, would I be able to hook it to the existing set up that I have. If yes, how would the connections look like. I noticed that there is a onq 2x6 video setup in the bedroom where the wires are connected(I am guessing from the roof). So if I have a receiver, where would all the wires be connected to.
(2) Is the SuperDish enough for receiving FTA?
I am sure these are very basic questions but I really searched but could not find the answers. Any help/directions is more than welcome.
Thanks in advance
superdish imo is much to small for any fta use. you might be able to pickup the odd super high power tp, but I wouldnt bother.
sadoun has some excellent packages where you get the dish, lnb, motor and ird for a very competative price.
Superdishes are good for Dish Network receivers only cause the superdishes have internal switches. True FTA receivers have no avail for internal switch settings like that of a superdish.
Maybe I'm wrong about that statement, but either way, you're better off getting a 30" or more dish, linear (standard) Ku LNB, and maybe a motor down the road one day.
The Superdish IS designed to pick up linear Ku, but the vertical axis is somewhat undersized. It will work, but I wouldnt' recommend it unless you have a blindscan-capable receiver since the Ku LNB (and the DBS one for that matter) is stacked. This means the LNB takes all signals from both polarities and puts them into a single polarity, "stacking" one polarity in a frequency range above the other.
43w 12050 H problem?
Newbie with elevation question
