Newbie help wanted | SatelliteGuys.US
Newbie help wanted
Affald
Hi, hope this is the correct location for my question. I want to get dish installed in 32159 Florida. Is it best to get the 24 month lock in, or will there be a better plan next week? Who should I contact for the installation? What should I look out for in the installation? Are referrals beneficial? Is it possible to use one or more of those dish receivers in the Dominican Republic? Any advice is greatly appreciated!! Thanks
Welcome to SatelliteGuys Affald! Moved your thread here so that you will get some responses.
24 agreement is standard, and not likely to change anytime soon.
Most of the time it is better to stop in at a local retailer that sells DISH.
This way it is usually faster to get service calls and help if needed.
If you have a referral by all means use it. It will give a credit on your bill and helps the guy out that gave it to you.
As they will get a credit also.
Agree with above, and also, you get to see the new equipment released today so that may sway your decision prior to getting Dish.
Reactions: navychop
the Dish 2016 predictions thread: Post your predictions here.
CES 2016 dish news conference will it be live streaming?
