Newbie Help Please - Getting 148 trying to get 121 | SatelliteGuys.US
game4lover
3
Hello,
Thank you starting to read this.
Last year, I bought an antenna (dish small) along with a dvb mpeg2 receiver from craigslist and was able to connect to 148 orbital location [based on what I see in the installation screens.] and was able to subscribe to a couple of international channels for a few months. So far so good.
This year when I called dish, they said, I need to upgrade and get $199 to get a different set of International channels. Dish network site says these are in 121 satellite.
Again I went to craigslist and bought a 32inch dish with Ku-band LNB. I replaced the old dish with the new 32 inch dish. Same cables, same reciever.
I am unable to hook up to any satellite. First of all, am I on the right track ? Can I make this work ? Should I get a new receiver or would the same configuration work ?
If you have read this far, thanks again for taking time.
Thank You,
G.
What are you using for your elevation and azimuth?
Thank you for a quick response.
I am using the values from the Dish Network installation screens for 121
Azimuth - 162 I am using a compass to get there.
Elevation - 46
I am not sure about the value skew which is shown as 89.
I tried to connect to the 148 / 119 without success [which I am able to still get using the old dish even now ]
Thank You,
G
What model receiver do you have? What channels are you trying to subscribe to? Did you buy a Superdish for 121 or are you trying to use a Free To Air dish? The more information we have the easier to give accurate answers to you question.
Thank You for your response. Here are some additional details :
Receiver Model : 4900
I do not have a superdish. I do not know what a "free air dish" is. But the one I have is a 32" dish made by TMTHOME dish company, I guess in China.
I am trying to get channels from
Satellite 121 Transponder 17
or
Satellite 118.7 Transponder 706
Thank You.
G
or
Thank You.
G
You need a superdish to pick up 121 but that uses a DP LNB which isn't compatible with the 4900 unless you use a DP adapter that will cost as much as another receiver. The 118.7 can be received with either a dish 500+(plus) or a 1000+ again it will use Dish Pro LNBs which aren't compatible with your receiver. I think your first post said that DISH would install a system for $199, take them up on it.:) :) :)
Uplinked vs. Available
Leaving Dish AFTER 4 YEARS
