gizzer777 said:Hope they put numbers on the Strength meters this time!
HAS ANYONE TRIED IT OUT...ANYTHING OBVIOUS.
Jeff
Cold Winter said:Well, I've run just about everything they've put out on the ViewSat. Generally, I'd say the most current .bin is OK. If by numbers on the S&Q meters you mean "%", thats still there. Just not on the info bar when you watch TV. USALS is pretty solid ( has an annoying habit of drifting back to the sat your last channel viewed was on while your in Setup ).
So far, I'd say its small things that need fixing. In my case, it seems that ViewSat still has problems with L.O. freqs on the Invacom Universal LNB and tuning some parts of the band. This is probably similar to another problem reported where the VS can't seem to handle a STAB120 in the path to the LNB. Both channel scans and Blindscan seem to work OK, outisde of my L.O. freq problems.
I am getting ready for a trip, wiil use some sort of adapter to flash the thing! if they did not do the numbers on the normal meter (not the install mewter) the older firmware is fine here!
thanks
Jeff
You just might want to give it a go.
Limited time offer
