new system user | SatelliteGuys.US
new system user
topgun_iceman_929:
4
FLORIDA
Hi guys < I just got my fta system , I hooked it up as per directions . i need to know what i need to do next to program the sats i want ? I Have the following system : PANSAT3500S , INVACOM QUAD LNB , SG2100 DISH MOVER, 90 CM 36" DISH . IM AT 34690 ZIP IN FL . >> LAT: 28 LONG:82 DEGREES. CAN YOU STEER ME TO THE RIGHT LINKS IN NEED TO PROGRAM my system correctly with settings , d/ls ? Is any one in my area seeking my 7.5 foot C-band dish also for sale . many thkss
I would advertise your BUD in the classified area here at SatGuys.....
WELCOME to the satelliteGuys.US FTA forum!
Code:
   Holiday, FL 34690
Latitude 28° 11.478'N Longitude 82° 43.674'W
              Sat Name Sat Lng Az(t) Az(m)   El  Skew
          Intelsat 905   24.5W 106.3 110.9 19.5 -57.8
          Intelsat 907   27.5W 108.2 112.8 22.1 -56.9
         Hispasat 1C/D   30.0W 109.8 114.4 24.3 -56.0
          Intelsat 801   31.5W 110.8 115.4 25.7 -55.5
          Intelsat 903   34.5W 112.9 117.5 28.3 -54.3
           AMC 12/T 11   37.5W 115.1 119.7 30.9 -52.9
               NSS 806   40.5W 117.5 122.1 33.5 -51.4
             Pas 3R/6B   43.0W 119.6 124.2 35.6 -50.0
                Pas 1R   45.0W 121.4 126.0 37.3 -48.8
          Intelsat 705   50.0W 126.3 130.9 41.3 -45.2
          Intelsat 707   53.0W 129.6 134.2 43.7 -42.8
          Intelsat 805   55.5W 132.6 137.2 45.5 -40.5
                 Pas 9   58.0W 135.7 140.4 47.3 -38.0
              Amazonas   61.0W 139.9 144.5 49.3 -34.6
            EchoStar 3   61.5W 140.6 145.2 49.6 -34.0
             Rainbow 1   61.5W 140.6 145.2 49.6 -34.0
              Nahuel 1   71.8W 157.8 162.4 54.9 -19.5
             DirecTV 1   72.5W 159.1 163.7 55.2 -18.3
                 AMC 6   72.0W 158.1 162.8 55.0 -19.2
             Galaxy 12   74.0W 162.0 166.6 55.7 -15.8
                 SBS 6   74.0W 162.0 166.6 55.7 -15.8
               GOES 12   75.0W 164.0 168.6 56.0 -14.1
                 AMC 5   79.0W 172.1 176.8 56.8  -6.9
             DirecTV 3   81.8W 178.0 182.7 57.1  -1.7
               Nimiq 2   82.0W 178.5 183.1 57.1  -1.4
          Brasilsat B3   84.0W 182.7 187.3 57.1   2.4
              AMC 2/16   85.0W 184.8 189.4 57.0   4.2
                 AMC 3   87.0W 189.0 193.6 56.8   7.9
                  IA-8   89.0W 193.1 197.7 56.4  11.5
             Galaxy 11   91.0W 197.1 201.7 55.8  15.0
             Nimiq 1/3   91.0W 197.1 201.7 55.8  15.0
          Brasilsat B4   92.0W 199.1 203.7 55.5  16.7
             Telstar 6   93.0W 201.0 205.6 55.2  18.4
             Galaxy 3C   95.0W 204.7 209.3 54.4  21.6
             Telstar 5   97.0W 208.3 212.9 53.5  24.7
             Galaxy 4R   99.0W 211.7 216.3 52.5  27.6
       DirecTV 1R/4S/8  101.0W 215.0 219.6 51.4  30.3
                 AMC 4  101.0W 215.0 219.6 51.4  30.3
            Spaceway 1  102.0W 216.5 221.1 50.8  31.6
                 AMC 1  103.0W 218.0 222.6 50.2  32.9
                AMC 15  105.0W 220.9 225.5 48.9  35.3
           Anik F1/F1R  107.3W 224.1 228.7 47.4  37.8
             DirecTV 6  109.5W 226.9 231.5 45.8  40.0
            EchoStar 6  110.0W 227.5 232.1 45.5  40.5
            EchoStar 8  110.0W 227.5 232.1 45.5  40.5
               Anik F2  111.1W 228.8 233.4 44.7  41.6
         Solidaridad 2  113.0W 231.0 235.6 43.2  43.2
              SatMex 5  116.8W 235.1 239.7 40.3  46.3
             DirecTV 5  119.0W 237.2 241.8 38.5  47.8
            EchoStar 7  119.0W 237.2 241.8 38.5  47.8
 EchoStar 9/Telstar 13  121.0W 239.1 243.7 36.8  49.1
            Galaxy 10R  123.0W 240.9 245.5 35.2  50.3
             Galaxy 12  125.0W 242.5 247.2 33.5  51.5
         Galaxy 13/H 1  127.0W 244.1 248.8 31.7  52.5
  Telstar 7/Echostar 5  129.0W 245.7 250.3 30.0  53.4
                AMC 11  131.0W 247.2 251.8 28.3  54.3
             Galaxy 1R  133.0W 248.6 253.2 26.5  55.1
                AMC 10  135.0W 249.9 254.5 24.7  55.9
                 AMC 7  137.0W 251.2 255.9 23.0  56.6
                 AMC 8  139.0W 252.5 257.1 21.2  57.2
            EchoStar 1  148.0W 257.7 262.3 13.2  59.5
            EchoStar 2  148.0W 257.7 262.3 13.2  59.5
 *** DBS SATELLITE ***
         EchoStar 3/R1   61.5W 140.6 145.2 49.6 -34.0
          EchoStar 6/8  110.0W 227.5 232.1 45.5  40.5
            EchoStar 5  129.0W 245.7 250.3 30.0  53.4
          EchoStar 1/2  148.0W 257.7 262.3 13.2  59.5
             DirecTV 5  110.0W 227.5 232.1 45.5  40.5
            DirecTV 7S  119.0W 237.2 241.8 38.5  47.8
Satellite Finder is (c) Copyright 2004, P. Lutus
Using the SG2100 here are the angles you will need to point true south....
Motor elevation = 62 deg.
Dish on motor elevation = 25 deg.
HI PSB & THKS , I got those settings right than accordingly . Now when i try to Program each Sats , dont I need the right settings for each Sat? like LNB TYPE? LNB LOC FREQ FOR MY INVACOM - QPH-031? 22HZ? DISQC? SKEW ? TP ? POSTIONER SETTG?SAT SCAN ? MY LNB IS ONLY FOR KU BAND SATS RIGHT ? Someone said for my INACOM QUAD LNB to set the LNB type to UNiversal & the "loc Freq" to 9750 or 10600 , is that correct ?? thks Rick
Wrong, the QPH-031 uses a L.O. of 10750 (On the L side)
(And an L.O. of 11250 on the C side)
KU band only!
hi PSb , Also when i tried "FLASH backing up DATA to SD card "as page 37 in book says , it doesnt work ?? hmmm ??? The date of Data says year 2001 ?? should I try updating to newer version ?? where do i get that at ?/ maybe a link ? thks again ?
Pansat USA... You probably don't need the update, but why not... I did and I don't see any difference. The flash should work, do you have a card reader, you can save it to your computer.
Al
yes AL i have a SD memory card & it doesnt save the Data from the Pansat 3500 to the card . I havent tried it from SD card to receiver yet . Ok is there an easy guide or chart that shows the settings for each KU satelite with all the RIGHt settings ? which Sat do i try to Find 1st at the most south position ? thks ?
Your true south sat is Nimiq 2. Since you have an Invacom quad you can use that. You might want to find and store it (using the data PSB gave above) before installing the motor. Once you are ready to do the motor, Set the elevation scale on the motor to 62 and the Latitude scale to your latitude of 28. Set the dish elevation angle to 25. All of this info is on page 7 of the 2100 manual. Now, aim the entire assembly toward Nimiq 2 (about 183 on a compass). When you are sure you are aimed right make SLIGHT adjustments in your dish azimuth and/or elevation (do not touch the motor settings once set) to "peak" the signal.
OP has been banned due to asking a hack question (asked it in a PM to a couple members)....and thread closed
Trying to steal Dishnetwork programming?
KDEV on mid-Missouri cable TV
