New Switch Needed w/ Super Dish | SatelliteGuys.US
parkers3
4
:confused: Does anyone know when the new switch will be available to hook my Sky Angel dish to my new Super Dish? (I got the Super Dish to get local channels.) The SW44 switch will not work with a Super Dish, and I was told by one technician at the Dish Network that they *thought* the new one will be called a DP44 switch. Unfortunately, depending on which technician I happen to be talking to, I get a slightly different story on exactly what I need and when a switch will be available. In the meantime, I am without SkyAngel (but fortunately SkyAngel will reconnect me at no charge when the switch is available).
So here are my exact questions:
1) Is the new switch actually called a DP44? :confused:
2) When will it be available? :confused:
3) Can I get it directly from DISH network? (One techie said yes; the other said no.) :confused:
Thanks!
Update on the "New Switch Needed" Saga
Here is an e-mail I just received on the subject....anyone else know of anything???? :no
Subject: Technical Support
Dear Mr. Parker,
Thank you for your email correspondence. At this time, the DishPro switch is still under development. We do not have a release date for it.
Sincerely,
Tom H.
Technical Support
Dish Network
********** Original Message **********
Full Name: Scott Parker
Question: Do you know when the new switch will be available to hook my
SkyAngel dish to my new Super Dish? (I got the Super Dish to get local
channels.) The SW44 switch will not work with a Super Dish (which one DISH
technician sent me), and I was told by another technician on the phone at
DISH Network that they *thought* the new one will be called a DP44 switch.
2) Exactly when will it be available?
other said no.)
4) Will I get free installation of the switch?
Look at the sticky on DishPro Plus technology in the Dish forum. It's actually called a DPP44 (DPP for DishPro Plus) and is supposed to ship in the next week. You probably won't need the other DPP44 features (single-cable drop for dual-tuner receivers and no adapter needed for legacy receivers), but it has the four inputs needed for a SuperDish-plus-SkyAngel installation, and it works with all existing DishPro equipment. (You won't need a DPP "separator" unless you use the single-drop feature; you probably will need the power inserter, however.)
Though you won't use it with a SuperDish, the new DPP Twin LNBF (coming in a few more weeks) is also a good thing for SkyAngel viewers. It has a built-in switch that takes a separate input from a wing satellite, so you can have a Dish500 plus SkyAngel with no external switches--just put the new LNBF on the Dish500, then connect the SkyAngel DishPro LNBF to its input. It also offers the single-drop feature, like the DPP44; we don't know yet if it also has the no-legacy-adapter feature.
Having trouble positioning dish just right!
Is the lifetime subscription to Sky Angel still available?
