GEOSATpro - New microHD Firmware Release: GSPMHD_0.15_12052012 Available for USB and Satellite Update (OTA-SSU) | SatelliteGuys.US
GEOSATpro New microHD Firmware Release: GSPMHD_0.15_12052012 Available for USB and Satellite Update (OTA-SSU)
  • Thread starter Thread starter SatelliteAV
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
SatelliteAV
6,486
186
Roseville, CA
Release: December 5th, 2012
Minor Operational Firmware Update is now available.
GEOSATpro firmware GSPMHD_0.15_12052012 for USB Update
or
OTA-SSU updating via satellite Galaxy 19, transponder frequency 12115 (Do not change any other settings in the Manual Update Menu screen).
Warning: The GSP_MHD_015 update is a main system file and will overwrite your settings and channel scans. We strongly recommend users to perform a complete factory reset after the firmware update. You may safely load any User Data Base (.udf) file created and saved from a microHD operation on firmware version 0.13 or newer. If you have an older User Data Base created with firmware older than 0.13, use the attached new Satellite/ Transponder list. If you use a switch or motor, you will need reconfigure and re-enter your location Longitude and Latitude settings.
Important Notice: Before updating the firmware, Please back-up your current firmware to an USB - Save to USB (ALLCODE) .abs
  • After the .abs firmware file update is completed, power cycle the rmicroHD by removing and reinserting the power plug. Perform a Factory Reset before reconfiguring the satellite settings and scanning for channels or loading the .udf file.
Important Clarification about loading .udf files created with previous firmware versions. We DO NOT recommend loading old User Database files (.udf) that were saved on previous firmware versions older than 0.13. While the saved .udf file may be fine and cause no operational issues, the file could contain data that will cause the microHD to enter a reboot cycle. Please follow our recommendation of rebuilding your channel list using the database file that is in this firmware.
MicroHD Firmware Release Notes:
Date: 12/05/2012
Version: GSPMHD_0.15_12052012
  • Corrected: Support high bandwidth HD feed channels without "i frame" reference.
  • Corrected: Satellite List - SM5 orbital location corrected to 116.8w
GEOSATpro ooopps, my microhd is rebooting.
GEOSATpro GEOSATpro MicroHD: How to Update Firmware (.abs) by USB
