New member introduction | SatelliteGuys.US
Not open for further replies.
1ofakind04
Hello new member here saying hello from North Carolina, so hello to all hope to learn the site navigation quickly and will offer help if we can but seem to need it more lately. I have a dish 500 and the dishpro twin lnb setup. I get the 119 sat. just fine but cannot get the 110 sat. at all . Zip is 27520 and using az. 237 elev.34 and skew 129. And just cant seem to hit the right button to get the 110 lined up . HELP>>>>>>>> The lnb unit has dishpro written on it and has 2 coxial post, and was told the switch is built in I dont know if it is or not, so thats why Im asking . I have my coax from lnb's to the reciever on the 119 post. then tried it on the 110 post and still no luck pulling in both satellites. Can someone point me/dish in the right direction.....and my wife has to have locals lol..... and I cant get them because it says they are on the 110 sat. local chanel here is chan 5 wral Raleigh NC area suppose to be at channel 8752 and when we got to that channel, reciever says no or bad signal. and that it is on the 110 sat . and as you have read cant get 110.... Thank U someone to straighten me out. Thought about getting a pro here to line dish but at @ $75 service call and on disabled income the budget does not support that now....
You have everything right as far as the cable and LNB.
You need to check switch first of, hit menu 6-1-1 go to check switch then check.
Two things if that does not work. Take the dish off the mast and make sure it is perfectly plub. Then line it back up, while you are pulling 119 in when you see it on the receiver then take your hand and cover the left side of the LNB up only. If the signal goes away then you have everything lined up right and 110 should be there. If not you need to go up with elevation then left with az.
Re: Log Homes
What's your guess??
