New install tomorrow | SatelliteGuys.US
erict
167
8
Well my install has finally come. Michigan microtech will be here between 8am and 12pm tomorrow. I will report back on their install. Can someone give me a quick simple cheat sheet on signal strength for all five transponders.
I am in the Detroit area so not sure which stats to look at.
101
110
119
99
103
someone posted these...he is in north carolina....these look really good:
Satellite transponders (32 total at 101º)
[Most of your standard definition channels are beamed from 101ºW]
1-8 97 100 97 100 97 100 99 100
9-16 97 100 98 97 98 100 98 100
17-24 97 66 98 99 97 100 97 100
25-32 97 0 97 99 97 100 96 100
Satellite transponders (3 total at 110º)
[Several HD channels are beamed from 110ºW]
1-8 NA NA NA NA NA NA NA 90
9-16 NA 87 NA 95 NA NA NA NA
Satellite transponders (11 total at 119º)
[A few HD channels, local SD channels, and Spanish package]
17-24 NA NA NA NA NA 100 100 99
25-32 0 100 100 100 0 100 100 100
Satellite transponders (6 total at 99º(s))
[Local HD channels for some cities]
1-8 73 60 0 91 72 37 NA NA
[Note: these can be very slow to appear]
Satellite transponders (16 total at 103º(s))
1-8 0 0 0 0 0 0 NA NA
9-16 NA NA NA NA NA NA 0 81
17-24 97 0 78 80 88 0 0 0
[Note, these can be very slow to appear]
Satellite transponders (16 total at 103º(c))
[Most national HD channels]
1-8 95 95 91 93 90 92 88 92
9-16 89 92 90 93 89 93 NA NA
17-24 97 NA NA NA NA 91 NA NA
Our those the numbers I should be shooting for in my area? Also I see he shows six transponders? I thought their were only five?
u said 6 transponders but i think you mean satellites....there are only 5....the 2 that are 103 are the same.
depending where you live some transponders may be inactive for locals etc but generally u want high numbers.
on the 101 #s should be high as they are only sd channels which are easier to get.
on the 103c its hd channels so you should try and have nothing less than 84 reading on most of them.
D* on Demand
