New Guy To Dvr Help!!!!! | SatelliteGuys.US
KAWASAKI2374
PURCHASED USED DVR FROM A FRIEND WORKED GREAT FOR HIM IAM HAVING AN ISSUE WITH THE CHANNELS LISTINGS I SET IT UP WITH ONE ANTENNAE INPUT WENT THROUGH SETUP ALL FINE BUT LOCAL CHANNELS DON'T MATCH THE LISTING FOR EXAMPLE I GET THE MINNEAPOLIS STATIONS BUT THE DVR SAYS NY4 AND MN11 IS ACTUALLY PLAYING AND NOT ALL MY CHANNELS ARE SHOWING UP.HAVE A TRIPLE LNB HAVE 1 REC IN BEDROOM 1 IN A BEDROOM AND THE DVR IN THE LIVING ROOM WITH FOR RIGHT KNOW ONE COAXIAL GOING IN TO THE #1 POSITION. TRIED THE RESET BUTTON STILL DIDN'T HELP. I KNOW I DIDN'T HAVE IT ON TRANSPONDER 1 WHEN I INITIALIZED IT. CAN SOMEONE PLEASE HELP:eek:
Really need to know what Model DVR you have...
As there are 5 different CORE types of DVRs
(Tivo-SD (multiple models), Tivo-HD (HR10-250), UTV, R15, HR20)
Did you activate the Access card under your account?
Or is it still tied to his?
Basically it sounds like the Access Card thinks you are in New York...
But you are in the Mineapolis spot beam area, so that is what the transponders are mapped to.
It would help if you QUIT YELLING, if you want help.
As ebonovic said, we need more info, not only receivers, but what type of dish did they install 3 LNB or 5 LNB ?
For full use of the DVR's (ones with dual tuners) you will need 2 lines (coax) going in to anywhere you have DVR's
Jimbo
Question about Directv installation procedure
phase 3 swapped for at9
