Santa was good to me this year. He left this brand new C2W-PLL LNBF under the tree. Going to try it on my 11 footer in the next few days.
Will do.Let us know the results....with pictures of it on the dish.![]()
It's reported to be one of the best performers out there. The heat sink will help tremendously in a high heat environment to keep the noise temp down plus it's has phase lock loop circuitry which should help on the weak transponders and the high forward error correction. I will post results when I can get a chance to swap out the one I am using now. Weather hasn't let me as of yet.I will say one thing. I've never seen an LNBF with a big heat sink on it before. That's cool looking!
All I did was changed out the LNBF. Same position on the bracket and same focal point.You got almost 2 full db better SNR just from switching the LNB? no dish tweaking anything? Thats unreal, like crazy unreal.
UDL
Excellent results! Is the dish motorized? Did you use the old scalar already on the dish or the new Titanium C2W- PLL scalar?All I did was changed out the LNBF. Same position on the bracket and same focal point.
I simply switched out the older LNBF with the new C2PLL using the new scaler that came with it.Excellent results! Is the dish motorized? Did you use the old scalar already on the dish or the new Titanium C2W- PLL scalar?
And yes it has a 54 inch Venture actuator.I simply switched out the older LNBF with the new C2PLL using the new scaler that came with it.
Limited time offer
