New Firmware GEOSATpro DVR1100c: GS_3.33 | SatelliteGuys.US
SatelliteAV
6,486
186
Roseville, CA
Released 11/30/2010
New Firmware Version for the Geosatpro DVR1100c V3.33 is now available for download via the satellite Galaxy19 KU OTA-SSU update on transponder frequency 12115, PID 330. USB and RS-232 versions of the firmware are available on the SatelliteAV website. http://satelliteav.com/portal/33/documents/DVR1100c_Firmware_Loader_Guide.zip
Fix: Random C-band TP Lock-up.
Fix: Increase scanning speed. Channels with no service name will not have a 45 second search delay.
Fix: Scan - previously would skip certain channels such as G18 - KU / Daystar.
Add: Providing Naming for TV and Radio services which are not properly referenced in the PMT.
Add: Blind Scan Scan Options: FTA / ALL - Assists in scanning only the Free channels or All channels.
Default: Blind Scan Ending IF Frequency: 1450 - Changed to match the most common LNBF LO of the Standard Type LNBF.
Default: Search Option changed from SAT (FTA) to 1TP (FTA) in Search Screen.
Default: OTA-SSU satellite, transponder and pids reassignment (press Red button in OTA screen) - This will allow the receiver to be updated from additional satellites and transponders if ever needed.
Update: Satellite List
The 200 does have a beta software from a few days ago if you do the upgrade. Check the thread in the equipment review area. I posted that info a few days ago
RTV/83w
Satellite Identification via Linux Command Line?
