New AO-51 schedule announced | SatelliteGuys.US
  • Thread starter Thread starter VO1ONE
  • Start date Start date
  • Replies Replies 0
  • Views Views 3K
VO1ONE
177
6
In a couple days, the easiest easy sat will get a bit easier to work, being placed into high power mode and with the PL tone (CTCSS) shut off. This will make it even easier to hear and easy to access even with an old clunker of a radio without a tone board.
Also, digipeating on the packet side is currently set to ON as a trial basis. D700's and the Kenwood APRS HT are ready to go out of the box to use this bird. Even if you can't hear it, someone with an Igate probably can. Set your path to VIA PACB-1 to use the DIGI. It's approved for unproto ops, keyboard to keyboard or APRS. Usually connecting through a satellite digipeater is frowned upon so try to keep to unconnected packets.
Vssb/Ufm mode will be back, by popular demand! This experimental mode was a hit last month and it will be on again. The uplink is 2 meter sideband and the downlink is the standard 70cm FM. You'll need to adjust your uplink for doppler so full duplex is pretty much a necessity. It's a lot of fun!
Here's the official schedule:
In order to support the Scouting Event in Asia the mode of AO-51 will be
change to High Power FM repeater on 30 December. That change and the
January schedule has been posted on the amsat web site. And included below.
73 KE4AZN
30 Dec
In support of TamSat Request for Asian Scouting Event
PL Tone is OFF as requested
FM Repeater, V/U, High Power Mode
Uplink: 145.920 mhz FM, NO PL Tone
Downlink 435.300 mhz FM
4 Jan
Enable the Tone, no Mode Change
Uplink: 145.920 mhz FM, 67 hz PL Tone
8 Jan
AO-51 Kid's Day Event (See info on Amsat.org)
Uplink: 145.880 mhz FM voice, 67 hz PL Tone
Downlink: 435.300 mhz FM voice
9 Jan
Opportunity for Digipeater Testing
9k6 Digital, V/U, High Power, PBP BBS (Pacsat Broadcast Protocol BBS)
Uplink: 145.860 mhz FM, 9k6 PBP Digital
Downlink: 435.150 mhz FM, 9k6 PBP Digital
Digipeater will be Turned ON
16 Jan
FM Repeater, V(ssb)/U FM (Experimental)
Uplink: 145.880 mhz USB
22 Jan
FM Repeater, V/U
9k6 Digital, V/U, PBP BBS (Pacsat Broadcast Protocol BBS)
1Question!
Invacom Quad setup ?
