Neusat receiver keeps powercycling | SatelliteGuys.US
kircpat
2
Hi, I have using Neusat SP 6000 for 6 months. Everything has bee working perfect. All of a sudden since this morning, as soon i try to Turn it on, it turns on, i see the Signal bar getting stuck and then the box powers down. It keeps powercycling continuously on it own. On the Box, the digital display just shows a number, its either 0, 1, etc.
What's going on?
As you turn the power on try holding the channel up or down key on the remote, the receiver might be having a problem with a specific channel that your on.
Music/Radio/Audio Only
Picked up a Traxis 3500
