Netgear xe102 problems | SatelliteGuys.US
Rod Williams
65
Huntsville, Alabama
Just got an xe102 for broadband connection to my 622 & 722. The first time I reset the connection on the 622 it found xe102. I was happy. Problem is it only held connection for a minute. I have tried repeatedly to get a connection with the 622 & 722 with no luck. The xe102 and the 622 are plugged into a wall plug(no strips). Am I just out of luck?
Rod
Sling Guide and DISHComm
vip 612 install
