Need Twinhan 1020A driver. | SatelliteGuys.US
coinmaster32
916
14
USA
I have a twinhan 1020a computer sat tuner and I can't find the driver anywhere. Does anyone have a copy of it?
what os i got a v 64 bit, these cards only work with less than 4 gb ram... also if u have a pci-e vid card its difficult to get these cards to work (the 1020a wants the first pci slot available & incorrectly reads the pci-e as the first available)... if u have linux i think the 878 is natively supported in the bigger distros
Search Free to Air PC DVB Discussion on this forum for this card drivers and usage details. Also it helps to ID your card revision properly, if you want to get certain clear channels.
One dish for Galaxy 19 and AMC 4
