Need to control a cable box in another location | SatelliteGuys.US
dave1025
2
I have been asked to install an LCD 26" TV in a bathroom, so my client may view shows while bathing or whatever.
The installation does not pose any problems, but, I do not wish to have the cable box located in the bathroom.
I had originally thought I would use a TV equipped with a cable card thus eliminating the need for the box, unfortunately, I must be out of touch with the world of technology, for sadly cable cards are a thing of the past.
Is it possible to locate the box in another area, then use the IR port in the rear of the box and run a less obtrusive fish eye style of sensor and mount it by the TV?
Hopefully someone has a clue on how to accomplish this feat, the cable company and retailers seem to be less than helpful.
Thanks in advance,
Dave
Thanks in advance,
Dave
Take a look at SmarHome, I'm sure you can find somethng to fit your needs.
Mounts in a 1/2" hole
Talkback LED confirms IR reception
Use with any connecting blocks
Easy three-wire connection
Installation and trim hardware included
Buffalo Round Micro IR Sensor - IR-350
Connecting Block Provides Link Between IR Remote and A/V Components
Xantech 1-Zone Connecting Block (1 Emitter Out) - CB12
Encore theme channels
New Comcast Chicago HD sub--a couple of questions.
