need some help | SatelliteGuys.US
need some help
johninillinois
55
will be moving in 4 weeks to a new place as i am getting married and was there earlier today with my future wife. i would like to go and put my dishes on the same pole as it close to my room i plan to put the high def in. and i can also make nice runs the other room i plan to wire with short runs of under 25 feet each.
has anyone uses the db-4 from antenna direct for this purpose as i have 4 stations under 15 miles from me in high def and are spaced from 94 to 101 degrees and thinking this should be a good choice.
i would love to have some help in picking a antenna to use thanks for your help and assistant.
What's your zip? I would think a DB-4 would be overkill because:
1) it's more directional than a multi-directional
2) you might be within multi-directional range.
did that this week
i did that earlier this week and was told the db-2 should be great in this situation. thanks for the help.
A Basic OTA question
how would u do this
