Need Remote Help | SatelliteGuys.US
Need Remote Help
Jimbo
Cutting Edge
Jul 14, 2005
70,174
8,533
NW Ohio - Buckeye Country
Hey Guy's,
Today while killing time, I thought it would be a good idea to set up my BR player to work on the D* remote.
I went to AV1 and set it up, it now works, at least the power portion, haven't gotten any farther (also was going to program mu Yamaha recvr).
Anyways, while programming my Pioneer BR player, I somehow LOST the programming for the HR24 .....
I can still turn the BR ON and OFF, but have NO function on the HR24 anymore.
Batteries are good, just changed them and I get the light above the D* logo.
Can anyone give me instructions to getting my remote (D* white rc65rx) to work the recvr again ?
I would just use the front panel to navigate into the menu>setup>remote and reset the remote. and start over from there.
That's how I would do it, but I'm not the remote expert either :)
I will try that, but I thought you had to do that FROM thew remote, maybe not.
I'll try that in a bit, gotta run out for a few, be back shortly.
Try MUTE SELECT with the remote on D* mode. Then enter 981. This code is used to clear codes on AV1, AV2 and TV. I don't know if it will reset D*.
Thanks Cave, :up
Yes that DID work, now to get back to RF and see if I can get my Blu Ray and Yamaha A/V recvr working with out screwing it up again. :D
Multi-room DVR Problems
NFL 3D
