Need hookup help with 921 & 721. | SatelliteGuys.US
TEN89
21
Buffalo NY
Could I use the DP34 switch? And how would I hook it up? I have 2 dishs 1 for the 119 & 110 and 1 for 61.5 The 119/110 is a DP twin LNB. The 61.5 is a sgl. My setup in the back of the house looks like I have 2 dp21 switchs going to the 61.5 and the other cables from the switch going to the 119/110. Then from the from the DP21's 2 cables go into the house to my 921. So the setup I have now. Could I get a DP34 and hook the 2 cables that I have going the house to my 921 put on to the DP34 and have both my 921 & 721? Thank for your help. :)
Same answer as on DBSTalk Yes to combine satellites a DP-34 will work. For the 921 & 721 you need 2 cables to each receiver. The alternative to adding cables is the DPP44 with 2 separaters.
thanks for the help. the dp34 is fine. i don't mind 2 more cables. thanks again.
Maybe this was covered but...
You can remove the DP21's and run one line each from both ports on the twin and one from the dual into the DP34. It doesn't matter which line goes on which port. You will probably have to do a 'check switch' on each receiver.
connecticut OTA help
Dish HD opinions
