Need Help | SatelliteGuys.US
Need Help
fak005
2
texas
Team
I have following setup
- Dish 500 with twin DP LNB to get 110 and 119 birds
- Dish300 with single DP LNB to get 61.5
- DP34 swtich
The DP twin LNB has 2 outputs, however I have used only 1output from side of 119 and connect to port1 of DP34. I have connected output of DP single LNB and connected to port2 of DP34. However, my receiver only sees 119 and 61.5 birds.
I cannot see 110 and I know my satellite is pointed in right direction.
I was told that I could use any single output of twin LNB as that shoudl carry both 110 and 119 signal.
Please let me know what I am doing wrong
thanks
Team
- DP34 swtich
thanks
That would be true if you were going directly to a receiver, but you are going into a switch before the receiver. You need two feeds from the Dish 500 to the switch, one for 110 and one for 119, and one from the 61.5.
Dish HD Fees?
Speed HD question
