need help with SuperDISH | SatelliteGuys.US
speedious
3
I have to use a 10 ft pipe to install the new SuperDish.
With its heavy weight, what size of pipe is recommanded? 1 inch or 1.5 inches?
Why do you need a 10 foot pipe. Do you have to clear trees or structures. How are you going to mount it? If its a ground mount and you have nothing to secure the middle with then you will need to use a bigger OD pipe and use a reducer at the top.
New Install Questions - Existing Coax, Dish1000, and Diplexers
resolution of the FOX OTA crash problem?
