Need help with signal solution | SatelliteGuys.US
neo1980
4
When I chose Dish 500 and get the highest signal for 119, i go to Check Switch, it does all the tests and gives back 1 as 119 and the 2 as 61.5 for odds and evens , when it should be giving 110. Then I go back to the signal screen and chose Check Switch and instead of clicking Check I click view and instead of 61.5, theres 110 for 2 instead of 61.5 as it was before.
So now i think everythigns done and when i click on a channel which is on the 110 signal it says "satellite signal has been lost, trying to acquire satellite signal. etc etc"
What should I do
Dish 510 for sell!!
New PVR 721 Activation
