Need help with new dish | SatelliteGuys.US
glocknwva
2
Hey guys i see you all talking about the Channel Master 3040642-01 mod # 1.0m-3 I just scored one free but it lacks the lnb mounting rods I also need a mount that I can use with a positioner any ideas or should I just buy a new dish i'm just now starting to get in to FTA i'll prob be getting the viewstat Xtreme rec. and a Invacom QPH-031 LNB.....
Help :)
Thanks Guys
John
Glock -
There are threads around here on removing the heavy stock mount, and making your own light one, to use with the H-H motors.
So, I really wouldn't worry about that part of the problem.
If you're crafty, it's not that big a job to work out where to locate the LNB - but it'd be up to you to fashion something to hold it.
It all depends on how mechanical and creative you are.
actually, as soon as I find one of those 40" dishes, I have my own mount-design I want to fabricate :)
Help :)
Thanks Guys
John
I have a 1M P* dish in my shed right now if you want I can take some pics of the lnb arms and the measurments for you if you want me to...:D
FWIW you can buy a joint of 1/2" electrical conduit and fashion your own lnb arms, if you ever have to. Of course you need the measurements, and a pipe-bender to do it right.
charles
Hey guys thanks for the quick reply and I have located the lnb poles but there is no center piece to mount the poles / lnb to i took a pic of the poles that i found and temped them to the dish: http://i15.photobucket.com/albums/a393/joecable69/equip/wg500x.jpg now I guess i'll have to make that center piece. Do you all like this dish for FTA?
John
I've seen some CM feed assys on flebay lately that have the junction block with them, would be much better to use their feedhorn than a generic type LNBF anyway.
As for a mount, I hear they have quit making the polar mount for them now, the 1.0 and 1.2 used the same one.
P* Aiming...I'm Totally Lost
The best location for Ku FTA !
